I could use another set of eyes and help with this idea (pickup simulator)
My goal is a midi controlled pickup simulator. I have oscillator devices trash pandas and garbage collectors, so really just need an externally controlled device (using expression and tap). I have no experience with vero/strip board design so off the shelf as much as possible is ideal.... now if someone wanted to design and sell me something with all this combined, I would not complain as I'm a few months from actually needing this.
However, working with your standard google AI this is what I've come up with, just want to make sure it will satisfy my needs. Thank You:
Here is the final 3-Board "MIDI Virtual Guitar" rundown:
Board 1: The Inductance Hub (MAS Effects Pickup Simulator Kit)
  • Role: Provides the essential transformer inductance for the Fuzz Face interaction.
  • Wiring: Leave the manual slider switch pads empty. These three pads connect to Pole 1 of the Relay board.
  • Enclosure Placement: Position this low in a 125B enclosure to leave room for jacks.
Board 2: The "Identity" Switcher (PedalPCB Intelligent DPDT Relay Module)
  • Role: Acts as the MIDI-controlled pickup selector.
  • Control Input: Connects to the 1/4" SW output of your Oscillator Devices Garbage Collector.
  • Pole 1 (Inductance): Swaps the signal between the transformer's Full Winding (Humbucker mode) and the Center Tap (Single Coil mode).
  • Pole 2 (Capacitance): Swaps between a 22nF capacitor and a 47nF capacitor. These capacitors will be mounted on Board 3.
Board 3: The "Controls" Hub (Generic Stripboard/Veroboard)
  • Role: Houses the Vactrols for Volume/Tone and the capacitors switched by Board 2.
  • Vactrols: Two Xvive VTL5C1 Vactrols.
    • Volume: LDR side acts as the Volume pot, controlled by the Garbage Collector's EXP 1 output.
    • Tone: LDR side acts as the Tone pot, controlled by the Garbage Collector's EXP 2 output.
  • Capacitors: The 22nF and 47nF capacitors are wired here and run to Pole 2 of the Relay Board.
Hardware Summary
  • Enclosure: 125B Aluminum Enclosure.
  • Jacks (x5): Lumberg KLBM 3 1/4" Jacks (In, Out, EXP 1, EXP 2, SW).
  • Power: Standard 9V DC jack.
How it Works Via MIDI
  1. You send a MIDI Program Change message.
  2. The Garbage Collector interprets it.
  3. It sends a control signal to the PedalPCB Relay board's SW input, which simultaneously flips both Poles.
  4. It sends new voltage values to the two Vactrols, moving their "knobs" to the preset positions.
This single setup provides complete, accurate, MIDI-controlled analog guitar simulation
