Caldo71
Hey Folks,
So I just finished this fun-and-easy-build, and it sounds great, but it got me thinking about messing around with what frequencies the "bass" and "treble" knobs actually affect.
So much so, that I socketed some of the resistors and capacitors that I THINK are responsible for tonal response, so that I might swap them out for components of different values once I know how to calculate all that—hence my forthcoming question.
Now, I am still very much a novice "schematic reader", but if I understand correctly, these two capacitors and one resistor per EQ knob that I've pointed out in the schematic below are the components that make the magic...
...so those are the ones I socketed.
So here is my question (finally): is there some kind of online calculator or other handy way of easily figuring out how swapping out these resistors and caps will alter the EQ frequency?
I know there's lots of talk about THIS particular online gyrator calculator being handed out on this and other forums...
www.muzique.com
...and the same guy publishes THIS cutoff frequency one...
www.muzique.com
...but it seems to me that those aren't quite right, given the fact that the Integral preamp uses ONE resistor and two caps, rather than the "two-and-two" or "one-and-one" that those online calculators utilize? If I am even reading the schematic properly in the first place. OR, am I supposed to actually be factoring in the potentiometers as the second resistor, hence making the gyrator calculator relevant after all?
Any insights that could set me on the right path to being able to do these kinds of mods would be hugely appreciated!
Guitar Pedals: Gyrator Filter Calculator
Calculate freuqency cutoff for guitar effects pedals with vacuum tubes and solid state electronics. FREE calculator.
Guitar Pedals: R-C Filter Calculator
Calculate frequency cutoff for guitar effects pedals with vacuum tubes and solid state electronics. FREE calculator.
