JFET vs diode
Mike McLane
I've built a number of "diode/LED" dirt boxes, but no JFET. JFET seems to be considered the solid state counterpart to the vacuum tube so I was considering Son of Ben as a sort of second "dirty channel" for my Deluxe Reverb. Interested if anybody feels like there's any magic in JFET boxes.
JFET drives most definitely have some magic. Maybe someone more technical can chime in and explain their non-linearities and clipiping characteristics. I think it's safe to say that they can emulate tubes better than any other solid-state devices.
Some things to consider:
- JFET's have a limit of how much gain they can deliver.
- Most JFET designs rely on J201's, which are in short supply, to get enough gain.
- Amp Emulators that use JFETs (Catalinbread stuff, RoG stuff) often use cascading gain stages which typically raises the noise floor quite a bit, even when you set the gain low.
- It seems like most people prefer JFET circuits based off simple tube preamps. These usually don't have a ton of gain but impart a little bit of a magical essence (everyone uses different descriptors).
- Running JFET circuits at 18V is the easiest way to squeeze out more gain, but requires rebiasing.
