YourGuitarist
Planning on working with the CD4044BE NAND gate IC.
Not having an easy time interpreting the datasheet rn. I'd like to drive an red LED with the output.
Does the IC have enough current drive or should it be fed into a common collector?
Also I can't tell fs but it seems that it may be noisy at the inputs? It's only binary logic, will that be an issue?
