Are you guys (especially Chuck, since I had originally posted it on the Boneyard) familiar with the Maestro Fuzztain? It uses the N-channel mosfets of the 4007 in parallel as a variable resistor in the compressor part, if I understand it correctly.
Do you think there is a very solid reason for the the mosfets to be used in parallel or could we, for example, use one of them for compression and two for the dirty stage?
