built a few of these stock. like the sounds. attempting a relay switched soft touch version like the real deal this weekend.
I'm considering making one in a larger 1590bb with some mods. Here's what I'm thinking, and I'd be down for any feedback or knowledge.
1.) diode clipping on a switch (i have this figured out and tested. Likely go 1n914(stock)/red LED or GERM/SILICON/LED if i can figure out how to do three(im assuming an ON ON ON DPDT instead of ON ON? diagram below
2.) buffer on a switch (pedal PCB staff hooked me up with a diagram for this and i successfully added it to a stock build already, HOWEVER. I'm going to be trying it again with a relay switched board and may need help. Someone shared the layout for using the buffer with the relay, and i have the layout for it on a switch in standard 3pdt wiring....just need to marry the two if it's possible.
3.) Ruetz mod? Is it possible? I really liked this on my old rat builds. Adds in the lows and cuts gain. In a rat it's as simple as putting the 47ohm resistor coming off the IC chip leg on a switch. I'm less familiar with this circuit and don't see a resistor in the same place, nor does the value match anything in the schematic. Might not be possible at all, but if the results are anywhere near the same as they are in a standard rat circuit it would be neat to have. Almost like a distortion/overdrive switch......
Maybe I'm grasping at straws. Such a good circuit on it's own but I can't help but want bells and whistles just for grins.
