Modify Phase II LED Behavior?
faramir
Is it possible to (easily) change the LED behavior on the Phase II? It seems like when the depth knob is all the way to the left the LED is half bright and increasing it makes it go up and down from there. Could it be set to start totally dimmed and then the Depth control changes the max brightness?
There are two trimpots on the board. One controls the depth of swing and the other controls the LED intensity. Play with that and see if it does what you want.
