fontoponto
Would it be a good idea to cascade the two channels instead of having them in parallel or am I missing some important point not to do it?
I'm not aware you could without modifications.You could cascade the channels on the amp, so yeah, why not?
Wasn't that the idea with the 5 jacks? To have the possibility to go parallel ("Both in") or to go series: either brite --> normal or normal --> brite?I'm not aware you could without modifications.
I'm interested in the mod, so please share your method / experiences if it works out nicely!I willI just did not want to scratch traces on my perfectly fine finished Mofeta. I have to wait for the parts to arrive.
I don't see how they would help to modify the circuit to do so at all I'm afraid.It should work with some adjustments, the m800 and fornicus schematics should provide some inspiration!
Cascade is putting in series. Jumpers on an amp is parallel.You could cascade the channels on the amp, so yeah, why not?
No quirks or anything? I'm about to bring this board together with the outboard stuff,so, happy to see the routing explained! My mind doesn't wrap itself easily around things like thisSounds good!
I used a DPDT toggle switch but it can be done otherwise for sure
Code:serial <--> parallel S3 <- S1 -> S2 S5 <- S4 -> S3 S5 -> S6
