you won’t have much gain. Bring R4 down a lot, like 10k or even lower. Experiment with C3 for the bass cut, probably in the 22n to 100n range depending on what R you use.
The BM tone circuit cuts a lot of volume. You may find you want an extra gains stage, either op amp (since you have an unused half of a dual op amp, or you transistor (like the big muff has).
Could use an on-off-on switch for the hard clipping diodes. If the 4148s are on, you won’t hear the leds since the threshold is higher.
Every pedal circuit I’ve ever seen has a Cap from 9v to Gnd. (100uf commonly). The series 1n5817 is standard in all pedalpcb boards and I’ve adopted it for anything I make.
