Hi! New member here. I’ve built a 40+ pedals at this point so I’m not a complete beginner but I can’t say I understand enough to be an efficient troubleshooter. Finished my Nobelium kit from Das Musikding a couple of days ago
2 questions:
1: I had to flip the polarity on my audio device (Audient ID4) to get the XLR output and the 1/4” outputs to play in phase. I’ve never seen that mentioned in any of the Nobelium threads. Not a huge issue
2: This is supposed to be a really clean DI, right?
I had to set the trimpot no higher than a quarter of it’s travel to prevent some pretty ugly distorsion from the XLR out. I thought I might be overdriving the transformer but the 1/4” had the same distorsion around noon and upwards.
I’m pretty confident I’m not overdriving the input of the device or amp.
Tubes are JJ ECC82. Could be those? I don’t have any more ECC82s lying around, possibly a couple of 12AX7s and 12AT7s
I did ask Klaus about the silver mica for C6 that was marked 270J (=27pF ?) in the kit and he said that it was fine. Since it is a Silver mica cap it would be labelled differently. My DMM doesn’t have a Farad setting
If It was labelled conventionally after all, would a 27pF cap lower the headroom a lot?
The power supply is a One spot 1700mA
Bass is a Sandberg California active bass with a P style pickup and a MM humbucker. I stay mainly on the P pickup. The distorsion is present also in passive mode if I play a little harder. I did try another bass with a ridiculously hot Billy Sheehan P pickup in it. Same result
It does sound nice enough if I keep these pots low. Seems weird though…
Any help is appreciated
Cheers!
/Mattias, Stockholm Sweden
2 questions:
Cheers!
