drew.spriggs
G'day.
Been noodling through this design and made it up to the tonestack portion. The preceeding stage has a reasonably high output impedance, and I'm running out of board space.
It's a CMOS Muff-ish thing, so I've got 3 preceeding gain stages. A solution I found was using an active BMP tonestack (the tone controls are in the feedback loop) which looked like a great option as does double duty of having a low output impedance, but without vref already on board I'm out of space adding a DIP8 footprint, a voltage divider and filtering/decoupling caps.
Are there any interesting non op-amp tonestacks that you've seen? I know I could just go buffer>tonestack>gain recovery stage, but that would definitely be pushing it for space. I've seen baxandalls running off a single transistor so I am assuming it's possible to do; I just haven't seen many other examples of somebody doing it.
Thanks!
Thanks!
