Lytt Effects
Hey there, fine folks. One of my buddies has asked me to rehouse his OCD 1.2, which I am happy to do, but I need some help with the wiring. I think.
because the original power jack is hot glued into the enclosure, I’m not going to be able to get it out, so I’m going to need to replace it. We are also foregoing the battery snap, so I want to switch it up to standard Lumberg audio jacks as well, and also replace the footswitch. I have the OCD taken apart, and have most of the wiring figured out, but want to make sure so I don’t screw this up.
Pics:
When referencing things, I am looking at the PCB from the top. The pads for the wiring I will number 1-6 from left to right. The footswitch will be standard numbering 1-9 (1-2-3 left column, 4-5-6 middle column, 7-8-9 right column).
Pad 1 is GROUND, pad 4 is the PCB IN, pad 5 is the PCB OUT, and pad 6 is the + power. The IN pad goes to pin 5 on switch, OUT pad goes to pin 7. The TIP of the input jack goes to pin 4, which jumpers to pin 9, which creates the true bypass wiring. The ground pad goes to ground on the jacks, then to pin 6.
There are two more pads (2 and 3) that go to pins 2 and 3 (respectively). Pin 1 is left open. This is where I need help.
Basically, I want to switch it up to standard Lumberg power and audio jacks, no battery, and rewire it to be able to move the switch further down. Why can’t I wrap my brain around what’s going with pins 2-3 on the switch? Probably the beers I’ve had already. Help me wire this thing back up correctly so I don’t screw this up!
Pics:
