Audandash
Not verified yet but based on measurements it should be fine. Use at your own risk for now.
All leds are 3mm. I have the option for the voltage switch at the top. Remove it you don't want it. The cv output is on the side and a 3.5mm jack. Adjust size if you want. Generally I dont like side jacks bit this isnt your normal pedal. I was also nervous about putting the cv jack at the top since there is no way to get the wiring up there without going past the ic’s. I didn't want any unwanted oscillation. (Ironic for a pedal like this i know) Fredrik has that wire very short and to the side. He is the cmos/logic guy so i usually follow what he says on his projects.
https://drill.taydakits.com/box-designs/new?public_key=cUplT0xrYWcrVWhpNk1ianNkbXM3dz09Cg==
