125B Parasit U-235 Sub Octave
Audandash
Do “NOT” use yet. Top mounted jacks wont work. If you want to add side jacks go ahead. I am removing the top jacks. The trim pots and two caps are in the way. I will update with side jacks and mark verified once I check it. Side jacks have been added on the template but i have not verified yet. It should be fine if you want to roll the dice.
This is for a 125b instead of the original 1590b. I just do 125"s. Led is 3mm and placed where I like it. This is set up for top mounted jacks and a rectangle power supply. The original has side jacks as well. I honestly do not know if this will cause an oscillation issue or not. Hopefully not. If for any reason it does I will change the template to side jacks (ewwwww) and update it here
.https://drill.taydakits.com/box-designs/new?public_key=STFjbkV5ZzVIM2hpOWZYNlptZm5Cdz09Cg==
