125B PedalPCB Muroidea Distortion
gtfields13
Tayda Drill Template
I have created a Tayda Drill Pattern for the PedalPCB Muroidea Distortion (ProCo Rat) fuzz pedal.
There isn't a way to save notes to the pattern, so here are the deviations from the standard PedalPCB layouts
  • The in/out jacks are set for the Neutrik NMJxHC enclosed, chrome nose jacks (MNJ2HC-S is the unswitched version)
  • The power is set for the Same Sky PJ-011A jack. This design is also the the DC-1002 at StompBoxParts.
  • The LED is moved to my preferred position, and drilled for a chrome bezel, A-6043 at Tayda. If you use a buffer board on your switch, this location might interfere.
