125B Ppcb 3 knob with switches template
Audandash
First the led is 3mm and where I like it. Move it or change the size if you want. Second I use a rectangle for power. This can be changed easily. 8mm is pretty standard for the smaller non switched power jacks.
This is for 95% of the 3 knob projects on Ppcb. Robert follows a pattern generally and this is what i have come up with. I have used this many times. I added the 3 most common switch positions used by Robert as well. Delete the ones you don’t need. The top middle switch position is also often used for roberts standard led. If thats how your using it be sure to resize the hole appropriately. Double checking the positions is always good practice. For those of you that are following slong the switch positions are pot 2, 4 and 6 on a standard 6 knob. (Patterns)
https://drill.taydakits.com/box-designs/new?public_key=anNJMFo5b055S2dSenhrNVhBd2VhQT09Cg==
