Caldo71
Hey Crew,
So I have this fancy programmable analog EQ stomp box (Free the Tone PA-10G) that has a soft-touch 3PDT foot switch that allows one to toggle between four different user presets. And likewise on the other side of the pedal for on/bypass duties.
I'm about to re-house this sucker vertically in a rack-mountable enclosure, as I am wont to do with all my stuff, and I'd like to replace both foot switches with either a finger-friendly button, or maybe even a toggle if that is technically possible. The "on/bypass" foot switch I will DEFINITELY want to replace with a toggle, but the "program change" one is up for debate.
SO, TWO QUESTIONS/SCENARIOS:
- If the "program change" foot switch is to be replaced by me with a 3PDT toggle (and if that is even possible) would that be considered an "off/on", or an "on/on", or what? Looking at the unit, it appears to use the same exact part for both foot switches—see attached photo. So I guess that means that it's the same kind of switch used for program change duties on the let AS WELL as the on/bypass on the right? I didn't expect that to be the case. Can you guys tell me if I can use a toggle for the program change replacement, and if it needs to be "on/off", on/on" or whatever?
- Scenario two is if I just replace the program change footswitch with a finger-friendly pushbutton, and if the same "states" apply (on/on, on/off, etc) when purchasing those kinda pushbuttons. Or if I just look for a pushbutton that says "momentary" or something like that?
