P paulharvey New member Apr 8, 2019 #1 What's up with the smaller footprint for resistors on some of these boards? Ex. The photon vibe and the bass preamp Have smaller footprint than the Triangulum or the little green scream machine.
P paulharvey New member Apr 8, 2019 #2 Never mind. Figured it out. Those are using 1/8w instead of 1/4w resistors. DETAILS! haha
M mnemonic Well-known member Apr 9, 2019 #3 You can also use normal 1/4 watt sized resistors on those boards, they’ll just have to be standing up (like pic attached).
tdukes Active member Apr 9, 2019 #4 I like the way you alternate which side of the resistor is near the board. Should make shorting the exposed leads less likely.
