Resistor substitution
Mike McLane
Building a Maleficent MIds. Can't find a 3K3 resistor for R13. I have a 3K2. Close enough for government work??? From a design perspective how would it effect things? Please enlighten me.
Reactions: spi
If you have ever tested a 10 pack of resistors you know they can vary a bit. A 3.2 is pretty much the same as a 3.3. I’d use it. Or if you have several 3.2s check them and find the closest one.
You can also use 2 in series... I did that once. For example, use a 3k and a 300... Or a 2K5 and an 800.....
3.2k is within 3% of 3.3K. Depending on the tolerance of the resistors you're using, that's a measured value that would not be uncommon on a 3.3K resistor.
Given it's location on the schematic shown below, I wouldn't expect an audible change between the two values.
Like others have said, If you've got a few, you can measure the resistance of each one until you find the one that's closest.
*Edit* whoops, added pic below: Screenshot_20211115-094049.jpg
