JTEX
I thought I'd share this simple but very well-performing inline buffer/booster. It's intended to go onboard, but nothing's stoping you from using it as part of some other circuit, pedal, whatever. I made it following a request from a European luthier who found a very good sounding, but lower output pickup he wanted to use in one of his basses. The problem was that its level didn't match his other bass models, and the onboard EQ he's using doesn't have a gain trimpot.
Using the opamp shown, the circuit has the equivalent input noise of a single 5k resistor, the gain can go between unity and +20dB, current draw is <0.3mA, and the output can swing from rail to rail. For multi-pickup instruments, 2 or 3 units can be summed by simply wiring their output pins together, as if they were passive pickups in parallel.
