Digital Larry
https://github.com/HolyCityAudio/SpinCAD-Designer/releases
- Fixed introduced bug (build 1030) in simulator. Simulator again works whether or not scope is enabled.
- New "Vee" control block.
- Audio mixer blocks all have their lower level of "gain" preset at -18 dB rather than -24 dB.
- 4 to 2 mixer is now based on SpinCAD builder code and is consistent with the other audio mixers.
- Revised the "Instructions" menu to put Half wave and Absa (full wave) next to each other.
- Hooked up controls to ga_demo_wah to make it actually work with SpinCAD (for internal testing).
- Cleaned up some unused imports and removed deprecated Java code for Triple-Tap delay.
