Spirit Box Attack Pot value increase
Drlufk00
I was reading some info on the similarities between a Spirit Box build and another build that utilizes the PT2399 delay chip. The spirit box currently has a 10k pot for attack attached to pin 6 of the PT2399. The seabed delay uses a 50k pot connected to the same pin I believe. Theoretically would using a higher value pot for the attack on the Spirit Box provide a more robust delay (more repeats) or since the spirit box is labeled as a “pre delay” for the reverb, is the pcb/circuit not set up in a way that this is possible?
