t7 transistor tester
makisushi
At what voltage does the a t7 tester test a transistor? In this picture I have a NOS NPN silicon darlington Motorolla mpsa serie (I think it's a 13 but not sure), it reads 196 000 for gain... should I see a big difference between 1-5v or it's more notable a higher voltage?
See if you have a min max feature on your DMM. If so. use that
I can try to test mine whenever I get home tonight but iirc there's a 3.7v lion battery inside and it also displays the voltage on boot so it won't exceed those voltages
This is the best spec sheet I found with a quick look. I'm guessing 4.5vdc for transistors up to 30v for zeners but could be wrong.
well, max is actually around 5.3V 5.4V on my DMM. Battery is at 4.03v on the T7. Also, I don't think it was the same transistor this one is a Motorolla MPS A12 . gain is arround 110k
Almost certain I've measured this at around 3.3v
I'm not doubting you at all.
I was just pointing out it is possible to have a higher test voltage than battery voltage. I've built a couple of pedals with 18vdc available from a 9vdc input using charge pumps. Old battery powered tube radios (such as those used in cars) used voltage multiplier circuits to get high voltage required to operate tubes.
