The multi effect box I’m building has a mixture of PPCB, Aion, and Madbean pedals in it. I want to use the basic relay bypass board from PPCB for all of them. Is the BRB board compatible with these other boards?
If I want to toggle the led I can go DC+ to CLR to led to SW pad and then when the pcb is engaged the GND pad should complete that circuit?
The Aion boards (two maelstroms) look pretty straight forward the only thing is that the polarity protection diode and led/clr are on the breakout board Aion supplies so those will have to be added in (hence my previous question).
The madbean boards (slow loris and kompromat) have a few more connections. Mainly the J1 and J2 pads on the pcbs. It looks like they simply pass through to the bottom of the board so they can go to the switch. My thinking with those connections is I can leave the top pads disconnected and basically only run the pcb in/out from the BRB to the in/out pads on the pcbs. Maybe I’m overthinking this because all the BRB does is switch the pcb in/out into and out of the main signal flow.
TL;DR: anyone ever use a PPCB basic relay bypass board with Aion or Madbean boards?
