18 volts. This is a grey area for me. I'd like to understand it a little better. I understand not to run pedals at 18 volts if you use 16v caps.
If I only use 35v-50v, can I run these pedals at 18 volts?
If it has a charge pump, that's a no, no right?
If its some sort of fuzz pedal were biasing is required 18 volts isn't a good idea? unless the biasing is corrected?
are there certain common IC's that won't run at 18v?
Is there a list of pedalPCB pedals that you can run at 18? Or not run at 18v?
The pedalpcb king of tone is already at 18 volts dur to the charge pump?, but the original doesn't have a charge pump?
I hope this makes sense. It would be awesome if someone could guide me in this area. Or point me into the direction of something I can read up on.
Cheers
Cheers
