Paradox916
Like the title says I’m curious as to what I could use the charge pump board on.... any sort of OD/boost/ distortion? And is it worth the effort or just a fun add on that gives you a little extra head room?
Do you think a pedal like the Triangulum, Tyrian, or Valhalla would benefit from the charge pump mod? And you have to run a 18v power supply? I’m still learning a lot here.I think the Covert/Catlinbread DLSIII, Tweed Man OD, Drive 55 and the like benefit massively from having the 18 V option. I have it on mine switchable from 9 to 18V and it kicks butt.
If you use a charge pump like TC1044spca they don't cope with more than 12V or so, don't feed it more than 9V.Do you think a pedal like the Triangulum, Tyrian, or Valhalla would benefit from the charge pump mod? And you have to run a 18v power supply? I’m still learning a lot here.
