What should I mod to feed the Paragon(KOT) 18v directly?
Ariel
Since the Paragon goes from 9v to 18v internally, what should I change to feed it 18v directly? I have a spare 18v outlet in my power brick I'd like to put in use. Also, I read the modern King of Tone can run ''up to'' 18v, so, if needed, after the mod, I could simply run it in 9v as well?
The most important thing would be to check the voltage tolerance of your components, especially capacitors and ICs! Make sure they can handle 18v, preferably something higher like 25v.
Lots of people have done this before on here -
There are a few different options but they are all described on the forum.
I believe the recommended parts are already supposed to handle >25v. However, I will keep it in mind anyways, thanks.
They describe how to remove the jump to 18v to run the circuity at 9v. If i was to feed it 18v, wouldn't it be a different approach?
Same approach, then you can feed it 18V, so long as your electrolytic caps are rated 25V or (preferably) higher.
