bengarland
I'm building the DuoPhase, SuperHeterodyne, CaptainBit, and Arcana...
What pots do you recommend? e.g. for the B100K should I be looking at this one? Which shaft size variant do you recommend?
www.taydaelectronics.com
If I get that and mount it to the bottom of the board, will it line up nicely with the top of the enclosure?
Or do you recommend something else?
These are my first pedals I'm building "from scratch" after building some synths... so I'm new to trying to fit all of this in a pedal enclosure.
Thanks!
100K OHM Linear Taper Potentiometer PC Mount
ALPHA - Get It Fast - Same Day Shipping
100K OHM Linear Taper Potentiometer PCB Mount Round Shaft Dia: 6.35mm
100K OHM Linear Taper Potentiometer Round Shaft PC Mount
Thanks!
