Hello. I'm having some difficulty getting the size restricted capacitors for the Byzantium. Not all of the links on the parts list work.
So, I'm trying to track down a 1uf, 100uf, and 47uf capacitors. I've located a couple alternatives, but the lead spacing is 1.5mm whereas it looks like the schematic calls for lead spacing of 2.5mm. Assuming everything else is accurate, will these work or should I look elsewhere for the capacitors?
Thank you in advance!
