Hello all, anyone still here? I'm back at one of these builds and want to figure out why the advice that was given... was given. Jumping out C11, Why? just to reduce the FX signal a bit to compensate for the eliminated dry signal?
The MIX pot eliminated, but what if I did want to fix it 50/50? As easy as an R5k between 1-2 & 2-3?  As I am going to use this pcb for a pitch shifter as an octave up and want an even blend of Wet and Dry fixed.
The #2 Lug on the MIX pot goes to VREF Triangle, which represents what? Is that where the unwanted wet or dry signal goes that isn't passed along? It's not the signal source as it's coming from the left... Thanks for bearing with my questions, trying to better understand.
Similar question regarding Control 2 & 3... As a bass octave up pedal, I don't need anything from Control 1 as it's the lower octave.
Control 3 has to be fixed at full CW for the octave. Jump 2/3?
Control 2 also blends the octave 1 and octave 2, but what octave 1? I'm cutting out Control 1 signal all together. So, jump 2/3 there as well? Thanks!.
