Connecting Breakout Boards on Dual Switch Pedal?
apc42069
yoyoyo-
How would I connect two foot switches with breakout boards already soldered to them?
Can I simply run a jumper between Lug 8 of channel one to Lug 2 of channel two?
any help would be vvvvv much appreciated, thanks!
Find the lugs that correspond and run a jumper to them.
EDIT: You need to jump the Out on the one to the In on the other.
Ok cool - thanks man!
Wait actually, I feel like an idiot - sleep training my 6month old, have a heart lol.
Do I run a jumper from the pad of breakout board one (that typically runs to tip lug of out put jack) to the pad of breakout board two (that typically runs to tip lug of input jack)?
A picture is worth a 1000 words they say…
Not my build, just did a search for you… send your thanks to @Danbieranowski ….
I would have used one of my own build pictures. But I use an order switch to pick which FX goes first. All of it on a 4PDT switch to also activate a dual LED matching the FX LED letting me know which one is first. But that may have confused you :D
It wouldn’t have not not confused me lol - I HAVE been wondering how this is done through.. so a preemptive thanks for when I eventually get there! What effects have you got wired up here?
This is Episode Boost and Dirty Sanchez OD. Please note that the order switching breaker board is a specific one. It fits on a 4PDT and leaves the 3 lugs on the right for the dual led. If you look carefully you’ll notice that I put a resistor attached to each of the dual LED leg. It’s in the red and green shrink wrap.
