MichaelW
So I was originally going to post this in the "What's on the Workbench" thread but decided it was probably too long.
When built my P90 Tele it was a bit of an experiment with "over routing" pickup cavities to accept P90's.
I didn't want to invest in an expensive body in case I borked it so I bought a GuitarFetish "XGP" USA Spec body.
I've never used their bodies before, in fact I've never even held one of their guitars. But I was blown away by the quality of the body and the finish.
Considering it was a $90 body WITH a finish, I was amazed. The "XGP bodies are all USA specs and from my sample of two, use very good wood that's been well handled. (Eg, properly dried).
They use some kind of catalyzed finish but contrary to what I had expected, it's extremely thin hard coat and very well applied. Not glopped on poly like most imports and certainly way better than what I was expecting for $90.
I was so impressed that I used a coupon and bought a second body for a future project, which is what this thread is about. I have a soft spot in my heart for a Candy Apple Red 60's Strat. I used to own one....and in my misspent youth, the haze of drug addiction, substance abuse, etc....it got pawned at some point for drug money. (A rare glimpse into the true MichaelW...hahah).
Anyway, I got this body for about $80 as I recall. It's every bit as good if not better than the Fender branded Mexican Strat bodies that go for $250.
The finishes are a bit thinner. It's solid alder and just a tad over 4 lbs. So acceptable weight range. The CAR finish was gorgeous. Very deep liquid kind of red.
I've mentioned before that my "preference" is nitrocellulose lacquer for guitar finishes but I am also not a "nitro snob" as many of my guitars are either catalyzed or poly finishes and they sound great to me.
Having said that. I decided to continue experimenting a bit with this body. Since I only have $80 in it (I have more than that in a couple of pedals) I decided to see if I could knock down the "brand new shine" on the finish.
I'm not trying to "relic" the guitar, but rather just dull down the shine a bit, make it look like it's got some play and age on it. I watched a couple of different video's of how other people did it and decided to jump into the project today. All I have is the body right now, nothing else, so there's no big pressure to get it done and get it right so I can finish my build.
This is how the body looked before I started....
I used a random orbital sander with a medium Scotch brite pad. This is after the first pass.
After wiping it down I could see some spots I missed....
I decided to go from the Scotchbrite directly to Meguires Scratch X to start polishing. This turned out to be a mistake.
It definitely got the guitar to the luster I wanted but the scotchbrite left a lot of ugly little swirls......you can see in this pic.
Continued in next post......
