125B Daydream Delay / Pythagoras
DAJE
I have discovered that the 6 Knob Type 1 is a perfect fit for the Pythagoras, except the lower middle pot hole should be reduced to toggle size. Or not, too big isn't really a problem so you can just use the standard pre-drilled enclosure.
I was just coming here to see if there was a drill template I could make work for this pedal here. Awesome thank you
Here's the 6 knob type 1 drill template if you want to tweak it, but the standard pre-drilled enclosure should work and is cheaper.
The standard pre drilled enclosure worked great btw.
