mkstewartesq
Hello all. Am working with this more “hands-on” board than I am used to and wondering if there is any way to wire this up to a PedalPCB break out board? I’ve wired 3PDTs manually before and still can do that – but it would make things easier and quicker if I could just use one of the breakout boards that I have lying around. This is going to be the first pedal in line in a 2 in 1 enclosure so obviously I know all of the wiring coming out of the top of the board, to the jacks, going from the out of one pedal to the end of the other etc. is also going to need to be changed – but I’m really more concerned just about the breakout board possibility For connecting the 3PDT of the first pedal to its own circuit board.
(Once I get a handle on whether a breakout board can even be used, then I’ll figure out how to extrapolate that to using the breakout board with the illuminated foot switch, since that’s my ultimate goal.)
Thank you,
Mike
Thank you,
Mike
