mkstewartesq
So, being careless, I accidentally ordered a batch of the 3PDT Breakout Boards for buffered effects rather than the garden-variety kind I normally buy (and, worse, soldered a few of them to 3PDTs before I noted the slight difference in appearance). Can these be used as normal true-bypass breakout boards (i.e., by not connecting anything to the extra "BP" pad) or am I SOL and about to go through a lifetime's worth of desoldering braid?
If it helps, the affected PCB are the Little Green Screen Machine, Cetus preamp, and the Unison Double Tracker. I don't believe any ofthese are buffered effects.
Thanks,
Mike
Thanks,
Mike
