Solid core hook up wire…..
I use silicone insulated wire, whatever’s on amazon. It’s so much nicer to work with than the PVC. Zero burning or melting, looks fantastic.
I’ve got some XLPE insulated wire I bought for a repair on a car I had. 20 awg/50V/GXL in like 6-8 colors. I should use it for pedals. I think XLPE doesn’t melt easily if I remember correctly.
I just use Tayda 24gauge stranded. I don't have many problems with it. I don't seem to need to make 90 degree bends A majestically sweeping bend works for me. I used to use solid core but got annoyed with it snapping at the joint. Easier to get a cold joint too. Keep your soldering iron tip relatively clean and it's fine. Tin before every joint.
Sure, sometimes you get a bit of meltage but I don't mind tidying it up. I like teflon coated wire but it's harder to strip.
I use it for everything, just picked up 200' of solid core 20ga in yellow and purple for heater wires. If you want to save money, go to https://www.apexjr.com/
You have to communicate through email and send a check or give him your credit card number, but I've been getting wire from him for 20 years..... The LOWEST prices I've ever seen, huge selection.
Edited: It does not come on rolls, I had to roll this by hand, took about 40 minutes while I watched TV and imbibed tasty beverages late at night. I tested a couple small pieces to see how it'll look in an amp. I like it..... lol
He sells on eBay too, where you can just use PayPal: https://www.ebay.com/itm/174284212923
For those of you who didn't post which gauge you use, what is your preference?
(I see among the people who did between 18-24 awg).
With solid core I like 22, but with the pre-bond wire I like 24.
22 ga will actually handle all of the current in a high voltage amplifier, it's rated for more than that! I use to use 18ga on the heater wires but it's insanely hard to bend into intricate shapes. I use 20 on the heaters now and 22 on the rest of the amp except for grounding I still use 18ga. You want a HIGHWAY to ground to help prevent ground loops.
I will never use anything but silicone again. You can strip it with your fingernail and it doesn’t melt!
I like to use teflon because it is so thin and still is rated 600+v. Basically I like the esthetics. I like to use color coordinated capacitors where possible too, lol. And it's shiny and slick. And the wire is silver plated. I don't know why, but I really like silver plated wire. lmao.
I have POUNDS of mustard caps but I'm literally shelling out $45 for these pretty blue capacitors for the Bassman I'm building. Hey, I'm retired and love eating cheap food that's easy and fast to make. I have to spend my money SOMEWHERE..... 🤣
Worth it to me. Only time I ever use solid core is for tube heaters, so 50' is like a lifetime supply.;)
I'm used to dealing with him. The first time I ordered he shipped it before I even signed the check. After that I trusted him so I just send the cc number.... I check my bank and cc balance daily, and have disputed a few charges - all from "The L.A. Times" trying to resubscribe me without permission. I called the the last time to find out why and they said "Your wife called us and ordered it". I said "How is that possible since she died 18 months ago?". They hung up on me.....
I have a PayPal slush fund that my wife never sees or cares about. 'Nuff said.
Wow now I need to find some silicon purple stranded wire in the UK. I've only ever been able to get wire with insulation that'll melt if you look it funny over here.
DAOKI 22AWG Hook up Wire Kit 22 Gauge Silicone Wire 300V 10 Color 7m/23ft Each Stranded Tinned Copper Copper Electrical Wire Assortment Kit with 50PCS Heat Shrink, 70PCS Wire Labels https://a.co/d/0c1Iq4P
Not solid core but this is what I’m using right now.
