seangarland123
Hello! I am about to start my build of the Cleric Fuzz, and this will be the first time I've used an ON/ON/ON type of switch.
Specifically, my question is whether I use a PCB Mount switch, or a Solder Lug switch? Will either work? Is one preferred?
Also, anyone who has built this pedal able to share a drill template (no docs on PedalPCB). I need to figure out exactly where to drill the hole for the switch.
lovemyswitches.com
lovemyswitches.com
Taiway Sub-Mini DPDT On On On Switch - PCB Mount - Short Shaft
It’s a tiny toggle! The Taiway sub-miniature DPDT on-on-on toggle switch with short bat actuator comes with two nuts and a washer. Part number 200-MDP6-T2B1M2QE
Taiway DPDT On On On Switch - Solder Lug - Long Shaft
Be confident in your toggle switches with the DPDT On-On-On switch with solder lugs and long shaft actuator from Taiway. Part number 100-DP6-T100B1M1QE.
