comradehoser
Turning to the kindness and generosity of the PedalPCB community to help me think through some amp-related things.
Here was a simple idea I had since I have built several Sunn Beta preamps (before Sunn decided to Lazarus themselves)--
Use a 100w Class D power amp placed in a homemade enclosure into which I could plug power and audio for two Beta (or whatever) pedal preamps, with a blend for the two signals and a master volume control (maybe redundant). The preamp pedals are definitely capable of line level and maybe a bit more.
I got this icepower 100AS1 board (should have gotten the stereo version, d'oh!) : https://shop.icepoweraudio.com/wp-content/uploads/2023/02/ICEpower100AS1-2-Datasheet_1_6.pdf
It has a mains conversion circuit and an input buffer, so I don't think I need to worry about that. Not sure if I should put in an impedance switch at the end of the line, or if that's a consideration for Class D power amps. It definitely was for my OG Sunn Sonaro.
So, the question is, how do I, in all of my best-understanding-of-electronics-is-color-by-number-pcb-building self best go about the rest? I assume I have to fabricate a way for the signal to be split between the two pedals and then united afterwards, and stick a master volume potentiometer (A100K?) between the blended signal and the power amp in. The preamp volume knobs can handle the balance of the signals.
I am 100% sure there is something I am completely missing and look forward to learning from your advice in my most pitiful noobularity.
