Measured odd and common diodes IV curves
Holy batman, awesome! The legend has a too low resolution to read the names and the comments - at least on my ipad.
Let me know if you have any trouble exporting my data from plotly and I can email it over or something
I figured it out, I updated the HTML and excel master file 🥳
The DB9, are they the russian D9B? Curve is super similar to D9E!
Do you know the make/manufacturer of the 1N60 and 1N34A? cuz I have some in there already and trying to avoid duplicates,
feel free to review and let me know what you think !
Feel free to add details for the comment section for the legend, I will add the type soon, thanks again for the data, you rock!
The D9B is the Russian germanium, yep. I'm unsure of the manufacturer of the 1N60 and 1N34A but I believe all three of these germanium diodes were purchased from stompboxparts (I know for certain the 1N60 and 1N34A were). And no problem! Happy to see someone is compiling all of this!!
Nice work! Better resolution than my scope & curve tracer.
I found that with Russian diodes in particular, and Germanium diodes in general, that it's a good idea to test more than one of the same part # because there are some significant part-to-part variations.
Where the diode curve straightens out, the slope is the reciprocal of the diode's intrinsic resistance. You may notice that somewhere above 5mA, Ge diodes have a larger Vf than most Si diodes. It's because if that resistance. These curves are clear evidence that simply quoting a Vf number is pretty much meaningless unless the If is close to what the diode will see in your application. The majority of soft clippers run the diode current well under 1mA. Hard clippers might get up to a few mA, depending on the circuit.
i'm happy to add to the science
I tested 10x NOS KD521 against 5x current production 1N4148
I knew the fV was a little lower. The curve isn’t dramatically different. The 4148’s are astounding accurate to one another. The 521’s a little less so. A couple wild ones in there. Maybe that’s why we like them? They are a little less symmetrical in pairs? Or maybe that’s confirmation bias.
Awesome! thanks for that, we got similar results too! I did measure a 100 of each for these, couple of wild ones indeed looking at max measured for example that could have been an 1n4148. Main reason for me personally to like them is that they are obsolete, thus mojo scoring goes up drastically :ROFLMAO:
I personally tried most of these in big muff circuits and can't tell a difference whatsoever, but my hears should never be a reference to anyone, getting older :)
