Pharmacist Overdrive Daughterboard Wiring?
grobbins
Hello everyone
My first post on the PCB forum!
I've got a lot of pedal building experience but i've got a question for you. I've been working on a Pharmacist overdrive. When snapping the circled daughterboard from the sprue the part flew off and is not to be seen!
I am therefore asking if anyone can assist in advising on how this footswitch should be wired without the daughterboard
Cheers
G
Sorry if i wasn't more clear - The whole thing flew off somewhere so i don't have it unfortunately. I was hoping to wire it the old fashioned way
Welcome a-board!
Not necessarily helpful, but if you use the tayda drill template found here on the board, the daughter boards holes actually align vertically with the main PCB. I'm currently awaiting some 2.54 male male headers pins for this reason.
So a traditional wiring may be a little more cramped than traditionally so.
I don't know if Robert has a spare set laying around but he would be the man to talk to as it is probably specific to that PCB.
If you still had the Flying Debri, We could have done a continuity test to see which footswitch pad connects to the related little pads.
Welcome a-board!
Thanks for the info. Out of curiosity what resistors did you use for the weird value ones?
Cheers
