Digital Larry
Release Fixed Crossfade 3, renamed pins on 2:1x2 mixer · HolyCityAudio/SpinCAD-Designer
Crossfade 3, which is an attempt to create a "more" equal-power crossfade, wasn't working properly. But now it is! I've renamed the pins on the 2:1x2 mixer to make it more obvious which inputs get...
I'm taking advantage of having opened up the code again to make some small fixes here and there. I never know how long the desire to do this is going to last.
This time, the Crossfade 3 block got fixed. It is fairly simple and I don't know how long I scratched my head trying to figure out what was wrong. But with a fresh set of eyes (or maybe it's these new glasses) I was able to track down the issue and fix it. It's always in the last place you look!
I had the two inputs mixed up for control input between 0 and 0.5, AND the big one was that I forgot that AFTER a SKP instruction, the ACC is not usually 0, so you probably have to add a CLR as the first instruction.
I/O Mix - SpinCAD Designer
Ins and outs, gain adjustments, mixers, panners...
holy-city-audio.gitbook.io
I also updated the pin names on the 2:1x2 mixer (stereo mixer) to make it more obvious which pins are getting mixed to which outputs.
