Muffin Factory Input Resistors and other build information
Excellent work Feline! Tks. You're a lot quicker at doing this type stuff.
NOT quicker, I've just been thinking about all this stuff for a long, long while...
Gathering bits of info, ruminating, wondering, questioning, investigating, scheming, dreaming ... for years now.
Am I correct in stating that the two collector to base resistors (indicated with red arrows) in the Muffin Factory screenshot below are to bias the two germanium transistors? And that their values were selected primarily to bias the two Ge transistors?
You'll see a similar collector-base resistor in the input stage as well.
They're shunt-feedback resistors, and the clipping-stage ones operate the same as the input booster stage. Typically they should be selected such as to give about half of the collectors' supply-voltage.
