Caboose Overdrive - R16 Mod
R16 is a 12K resistor on the PCB/SchematicThe mod is to change R16 to a 2K2 resistor
Mod Improves pedal output volume and improves bias adjustment/voltage range (1.5v - 9v) on Q2 J201 Drain
Had two issues with this circuit, changing R16 to 2K2 fixed both issues.
Issues (R16 with 12k resistor):
#1 low output volume
#2 could not achieve standard bias voltage (4.5v) on Q2 J201 Drain
Anyone else have issues here with this build?
