SpinCad "Simulator" plays for two seconds, skips like a CD and stops.
So i just downloaded SpinCad on my new-ish macbook (I had previously been using my imac but thought I would try it on here) When I play the sample file for the simulator (or any 32768 kHz 16 bit stereo WAV file) it plays for about two seconds, skips like a CD and then stops. Once it stops I cannot get it to play again until I restart the program.
I'm not sure what I'm doing wrong. Maybe @Digital Larry would know?
Thanks!
Do you have the SpinCAD "Simulator/Set Sample Rate" setting properly matched to the audio file's sample rate?
What is the name and sample rate of the audio file being used?
Excellent suggestions and yeah, I did double check all that stuff. the only thing i can think of is a possible its a compatibility issue with M1 mac processors?
I use SpinCAD on three different platforms, M1Mac being one, and it works fine there. I use that same same wave file from GitHub and have had no issues. Is your M1's Java up to date?
Might be worth it to check Java versions. On Windows I have:
java version "18.0.1.1" 2022-04-22
Java(TM) SE Runtime Environment (build 18.0.1.1+2-6)
Java HotSpot(TM) 64-Bit Server VM (build 18.0.1.1+2-6, mixed mode, sharing)
@BrooksBlackhawk I tried it on my Intel Macbook Air and can reproduce your problem, sort of. I don't get any skipping but the playback does stop after a few seconds and doesn't start up again until I restart the program. The version of Java is very old. I ran SpinCAD in debug mode but saw nothing unusual. So it would be good to compare Java versions, especially one which does work on Mac. IME updating Java on this Mac is next to impossible. Perhaps there is a secret procedure for doing so. If someone knows I am willing to try it.
java version "12.0.1" 2019-04-16
Java(TM) SE Runtime Environment (build 12.0.1+12)
Java HotSpot(TM) 64-Bit Server VM (build 12.0.1+12, mixed mode, sharing)
OK, I tried the latest Java installer for x64 and it worked. I'm at version 21 now. The simulation playback issue on Mac remains. If someone out there wants to help debug it, let me know. By that, I mean install the Eclipse Java package on Mac and pull down the code and do "whatever" else it takes to get the program basically working. I did not write the simulator code so I have no more insight into it than anyone else besides the guy who wrote it. I have also never done the Eclipse installation on Mac.
As it would only involve the Java code (not SpinCAD builder) it would be a little simpler than getting the whole Java + Xtext + Xtend working.
DL
DL
I am lucky l have a desktop as well! I actually think I may have designed my first algorithm I’m really happy with. Now to figure out how to get it from spinCAD to an eprom without a third windows computer 🤣
I run Big Sur 11.7 on one of my MacBooks and Sequoia 15.x on another and have no issues with the SpinCAD Designer 'Simulator'.
For my Java experience, I run Oracle Java version 8.45 on both of them. I just went to the Oracle site and looked up "java downloads" and let the site display what was available for my machine. I've not heard of or used the "Eclipse" version. (Dunno what that is.)
I suggest removing whatever Java you have on your Mac currently and get the Oracle version from the link above.
"Eclipse" is the IDE I used to develop SpinCAD Designer. It's not the JRE itself. The Java version of Eclipse is the one you use to work on Java code. Why this issue is happening on Mac (even to me) remains a mystery. Thanks for your info.
DL
DL
Thanks Larry! I don't fuss with the inner workings of SpinCAD at the Java level. I roughly grasp the purpose now of Eclipse's roll in SpinCAD, but going there is just a bit daunting for me.
Last week someone volunteered via Github to look into this. Apparently, after they installed the Eclipse tools on their Mac, then the simulator started working properly. I've asked them to confirm JRE version but no response yet. I've always had some difficulty trying to update Java on my Mac running Monterey 12.7.6 so I basically gave up. Anyway, it's odd but if what they say is true it does hint at the Java environment being the root cause.
See:
@BrooksBlackhawk it would be interesting to know if the simulator works OK if you set the sample rate to 44100 or 48000. Apparently at least part of the hangup is that MacOS audio doesn't like 32768 sample rate. Here's a test build you could try that has a sample rate convertor built in. It worked a lot better on my Airbook.
