Tone Stacks - Part 2 - James & Baxandall
Chuck D. Bones
Circuit Wizard
First thing, here's a great resource on tone controls that I stumbled across after writing Part 1:
https://www.guitarscanada.com/attachments/10-tone-control-pdf.352944/
It contains the same info I'm presenting in these articles and then some.
James
E. J. James published the tone control circuit bearing his name in the February 1949 issue of the British magazine Wireless World.
It is a passive filter that introduces about 20dB of insertion loss when the BASS & TREBLE controls are centered. Originally designed for hi-fi use, it was adopted by guitar amplifier manufacturers Ampeg (left) and Orange (right).
The pots are usually audio taper to provide a uniform sweep. In the Ampeg design, the component values are proportioned to provide a flat freq response when the BASS & TREBLE controls are at noon. TSC shows that the Ampeg tuning sets the bass / treble crossover at around 1KHz, a little high for guitar amp & pedal use IMO.
The Orange circuit is tuned lower and less symmetrically.
The James tone stack really does not need a MID control because a mid notch is obtained by setting BASS & TREBLE above noon while a mid hump is obtained by setting BASS & TREBLE below noon. R4 can be tweaked to move the freq of the mid notch / hump. In fact, R4 could be replaced with a B500K pot in series with a 47K resistor.
The James tone stack shows up in the Viceroy pedal (below), tuned similarly to the Orange tone stack. It also appears in the PCBGuitarMania Acapulco Tone and the various Revv G pedals.
The advantages of the passive James tone stack are large BASS & TREBLE sweeps, tweakability, minimal interaction between the controls and the ability to set the freq response to flat. The disadvantages are the relatively high component count (compared to the Fender tone stack) and large insertion loss.
The James circuit can also be configured as an active filter. The Xotic BB Preamp is an example of an active James tone stack. The advantage of an active James tone stack is zero insertion loss and symmetric freq response. The disadvantage over the passive circuit is it requires a gain element, IC2.1 in this case.
Baxandall
Peter J. Baxandall published the tone control circuit bearing his name in the October 1952 issue of Wireless World. The Baxandall tone stack is classified as an active filter because it requires a gain element to function. In the Wireless World schematic below, the vacuum tube serves at the gain element.
Note that Baxandall used a tapped pot for the TREBLE control. The tap is actually not necessary as long as a DC path is provided from the grid to ground. With opamps or transistors, a DC path to the appropriate bias voltage is required. Usually, there are series resistors at both ends of the TREBLE control to limit boost and cut to reasonable levels. There is an alternate version of the treble control that replaces C3 with a resistor and puts series caps at either end of the TREBLE control (see the Acid Rain tone stack below). Sometimes the two bass capacitors are merged into one. The circuit does not need to be balanced. The caps or resistors can be deliberately unbalanced if you want more cut than boost, or if you want the cut and boost to kick in at different frequencies.
The Baxandall tone stack shows up in several guitar pedals: M.I. Audio Super Crunch Box (shown below) & TC Electronics Spark Booster.
The EQD Talons & JHS Charlie Brown have a Baxandall stack with an additional MID control crammed in. The added MID control is hard to execute properly. JHS got it right and EQD failed miserably. M.I. Audio added the MID control as a separate stage for the ultimate in control isolation. The treble portion of a Baxandall tone stack shows up in the Klon.
The advantages of this circuit are large BASS & TREBLE sweeps, minimal interaction between the controls, tweakability, the ability to set the freq response to flat and zero insertion loss. The disadvantage is the need for a gain element: either an opamp, transistor or vacuum tube. TSC does not support the Baxandall tone stack; if you need to simulate it, you'll have to use an engineering tool such as LTSpice.
Very interesting, thanks for posting this. I always thought that the James and Baxandall were the same but I guess they're not.
BTW, the Fender "G" (not G-A) brownface amps used these type of tone controls, but only for a short time before they converted to the "G-A" brown face Amps that had a more traditional (and cheaper) tone stack, Leo Fender always wanting to save a penny or two when he could.
There is one other important difference between the Acid Rain and a BMP: the coupling between the 2nd & 3rd stage. Instead of the typical 10K + 100nF, there is no resistor, just a 10nF capacitor. Has a strong effect on the tone. The first three stages of the Acid Rain are the same as the Noel Cornet Revu. The Acid Rain's Baxandall tone control stage is the same as in the Thorpy Fallout Cloud. Lotta very similar pedal circuits out there.
I’m not going to lie.. I love the stuff you cover, I have learned a TON from just reading your posts and threads while only understanding a fraction of it... it’s like drinking from a fire hose! But it gives me something to strive towards... It’s a lot like playing guitar for me I’ll never master it... I’ll just do a little better each time.
The two circuits are related and they do basically the same thing, just different ways. In his Oct 1952 article in Wireless world, Baxandall cites the James article from Feb 1949. That tells us he studied the James design during the development of his design. Negative feedback in circuits had been around for about 30 years when Baxandall wrote that article. The genius of Baxandall's design was putting the James tone controls in a feedback loop. Circuit designers these days take negative feedback for granted, but back then, it was still a new concept.
The Baxandall tone stack shows up in several guitar pedals: Colorsound Overdriver, PedalPCB Acid Rain, Thorpy Fallout Cloud & M.I. Audio Super Crunch Box. The EQD Talons & JHS Charlie Brown have a Baxandall stack with an additional MID control crammed in. The added MID control is hard to execute properly. JHS got it right and EQD failed miserably.
Emphasis mine. What makes the JHS successful and the EQ a failure? (For reference: PedalPCB Van Pelt Drive is JHS Charlie Brown v4, and PedalPCB Chela Overdrive is EQD Talons.)
Is it possible to easily "shift" a Baxandall tone stack? What I mean is, say the sweep for a frequency is -15 dB to +15 dB, and 0 dB with the pot in the middle position. What if wanted -9 dB to +21 dB, and +6 dB with the pot in the middle position? I.e. we rarely want to reduce, and only a little when we do; but we want a default (i.e. pot at noon) bump for that frequency, and a bigger boost range?
The Tone Stack Calculator has Baxandall support now. I tried playing with the values to achieve what I wanted, and I was kinda-sorta successful, but that was by the "guess and check" method. I assume there's a more methodical way to get this result.
If you have LTSPice, run a .ac simulation and look at what happens to the BASS or TREBLE sweeps when MID is a 0, 5 and 10. The EQD circuit does not provide enough any isolation between MID and the other two knobs. The Baxandall circuit was never intended to be a 3-band EQ. The BEST way to do it is to put the MID control on a separate stage. Doing it the way JHS did it is "good enough" for a pedal. There is still interaction between MID and the other two, but it's manageable.
In a Baxandall tone network, the BASS & TREBLE roll-off frequencies are determined mainly by the capacitors. The resistor between pin 2 of the BASS & TREBLE pots affects the TREBLE tuning to some degree. You can put the caps on rotary switches, but that seems a bit complicated for a pedal. If you want a reasonably simple, tunable tone stack, then build two or three Vari-O-Boosts, connect them in series and voilà! You have a tunable tone stack with fully independent BASS, MID & TREBLE boost/cut knobs. We can fiddle the cap values a little to optimize the freq range and Q for each band.
I have found that in most pedal circuits, I do not need a BASS knob that has a symmetric cut and boost range. Depending on where it is it the circuit, I only need cut or boost, not both. Same goes for the TREBLE knob. Baxandall might be nice for a stereo or maybe a small mixing console, but for a pedal or guitar amp, I think there are better ways to obtain the required EQ.
I have to agree. I am yet to find a pedal where James or Baxandall EQ stacks works demonstrably better than the simpler kinds of EQ you have shown me. And I'm probably missing something but why do they always seem to be symmetrical?
A couple other 3-band Baxandall EQ stacks in pedals: Catalinbread Silver Kiss, traced by Aion; Cornish CC-1/GC-1, also traced by Aion. In the latter, he also links to Elliot Sound Products Equalisers page, which is an additional general overview of common EQ types. Figure 7 on that page shows a 3-band Baxandall circuit.
+1 to that, that's actually what I was getting at in my previous question. IOW, I don't need the frequency to be variable, but rather the boost-cut range to be assymetric.
For reference: PedalPCB Mercurial Boost Build Doc, i.e. Vari-O-Boost schematic. And to see an explicit example of an "integrated" Varioboost, see Chuck's CMOS Overdrive Deluxe.
Above you mentioned the Crunch Captain Deluxe (MI Super Crunch Box) that has a dedicated mid control. At least superficially, it looks very similar to the mid control in the PedalPCB Cast Iron (Lollar Overdrive)... Are these dedicated midboosts essentially "1-band Baxandall" circuits?
One thing I can confidently say about 3-band Baxandall circuits: they are very hard to route cleanly in a PCB design! Three pots, an opamp, lots of components, and lots of connections between everything.
Sorry, Matt, I missed your "shift" request. As it turns out, it is very easy to alter the balance between boost and cut. I have done it in some pedal circuits.
Referring to the bottom schematic in post #1, we can shift the BASS control's boost/cut balance by altering R16 and/or R19. R16 limits the max bass boost. Larger give less bass boost. R19 does the same thing for bass cut.
It's not as simple on the treble side because C10 & C12 don't limit the max boost or cut, they control the corner frequencies. I don't like the James circuit for active filtering because there is no way to control the limits of the treble boost and cut. The Baxandall is better for that because the TREBLE pot has a pair of resistors that mirror the BASS pot's limiting resistors.
In reading about/trying to learn more about tone stacks, I came across this: TI TL082 Datasheet: Under the "Typical Applications" section, page 12, Figure 28, it shows the circuit for "Three-Band Active Tone Control". Looks to me like the 3-band Baxandall tone control.
Looks like that to me too. But...
Here's what you need to know about the Application Notes in datasheets. Some of the circuits work. Some of them don't. Some of them don't work as well as they could. The manufacturers should put a disclaimer on the datasheet that reads like a software EULA. It should state that the circuits in the App Notes are not guarantees to do anything good, and maybe not anything at all. Manufacturer is responsible for collateral damage if you decide to build the circuit, yadday, yadda, yadda. Seriously.
Linear Technologies (now owned by Analog Devices) was the first, and AFAIK only, chip manufacturer to actually build & test the circuits in their App Notes. If you can get a hold of the Linear Technologies 1986 Application Notes book, it's a gold mine.
This is the EQ of the Xotic BB "preamp":
This is a Baxandall EQ? This is one pedal where the EQ does seem to work quite well, although I use a C taper for the Bass pot and would love to know how to tweak it. As I am pretty much completely electronically illiterate I can't for the life of me understand how it actually works.
In the pedal I have which uses this EQ at the moment the EQ works ok, but the Bass control is way too thin sounding at anything below about 9-10.00 and I wouldn't mind if it got a little beefier at max. Do I adjust R18? The caps either side of the pot? I have been playing around with the rest of the circuit all around it and have avoided doing anything with the EQ. Can I tweak this EQ?
It is a dual bass capacitor Baxandall EQ circuit. To adjust the bass cut / boost you'd need to modify R16, R17, C11, and C12. The general philosophy (and I'm greatly simplifying a lot and sure I'll be corrected :) ) of the Baxandall EQ is to keep the mids flat and either roll off or boost the treble or bass.
You can play with the values of the components to tweak it by looking at something like this: https://tonestack.yuriturov.com/ where you can adjust all the values and then tweak the pots and see how the signal is changed.
No, that is an active James tone stack. In a Baxandall, C9 & C10 are replaced with resistors, R19 is replaced by a capacitor. I had to go back and correct post #1 because I mis-identified the active James as Baxandall.
If you are using any taper other than B, then you are getting an asymmetric cut / boost profile. C-taper skews the asymmetry towards boost because at noon, the knob is well into boost territory. Put another way, to get to a flat response the knobs must be set to 3 (10:00). If you are satisfied with the entire range of the BASS & TREBLE knobs, then stick with the C-taper pots. If you want a more uniform sweep, with noon to be something other than flat, then use a Baxandall configuration, B-taper pots, and unbalance the resistors on either side of the pots. Dialing-in your particular circuit is outside the scope of this discussion.
