Has anyone actually pulled and tested vintage components so we know 100% what the hell the actual readings are, say Hfe or Vf?!??
I found out this the hard way with the whole MXR RR-104 fiasco. They released a limited run of D+ pedals supposed to be 100% to Randy Rhoads original pedal spec and finally put to rest rumors that his pedal may have been modified.
I purchased 2pc not knowing they were going to be limited, but one to keep in the box or give as gift to another Rhoads enthusiast and the other to play.
My pedal although nice and heavy, sounded nothing like my vintage 1978 and 1980 D- pedals! When investigated...what I found out was the Vf in the 0.6xx to 0.8xx range. The original pedals only run like 0.320 to 0.360-ish, so much more clipping and distortion and no wonder the thing sounded like shit and cleaner and not enough gain! This was inconsistent throughout the run with some having the correct range and many, including both of mine way out of spec, so I ended up selling both off!
I really would like someone....may do it myself have a dedicated page to these vintage pedals....TS9, OD-1, SD-1, D+, etc. and test the components and provide the specs of the transistors and diodes so that people can match them up instead of people saying....just throw in a 914, or 4148 or whatever and you end up with a similar situation above and the Vf supposed to be 0.350, but is more like 0.650 and you're wondering why the fuck it sounds like shit!!
Likewise, this will protect against bogus parts. I had a recent example of this when I decided to just twist up a Distortion+ and wanted vintage specs. I picked up 1N270 from 2 sources and the diode Vfs were off and again, sounded like shit! I found a source of 1n34a's, which should be like 1N270s and the guy suggested testing in the 0.340 range. I picked up a set of 20pc and sure enough, they tested in the 0.340V range, so he was right and these part exactly to proper spec and sound great!!....but we HAVE to know what the original pedal specs are!
