Synth pickups
drgonzo1969
So I have a Brian Moore guitar with synth pickup built in. I’ve had the guitar for 20 years and never plugged the synth pickup in because I never had any 13-pin device. I’ve been browsing reverb for cheap old guitar synth stuff. Just curious if any of you are using 13-pin guitar stuff. What would you get? I’ve been eyeing old Roland stuff GR-50, GR-09, and GR-01.
Was thinking about the converter first. But 200,- is kinda steep if you decide to merely mess around a bit with it...
What about this thing. It does banjo <3 ... And sitar, among a range of things. A little less synth than the options above though.
"With the hex pickup installed, the GP–10 opens up a whole host of possibilities. You can, for instance, transform your guitar, through Roland’s COSM modelling, into different types of guitar. The COSM models track with extremely low latency and very high accuracy because they’re based on your actual guitar sound, rather than on MIDI. The models include various acoustic guitars, Strats, Teles, humbucking pickups, hollow bodies, dobros, a banjo, and even an electric sitar. You can change tunings at will, and add a tunable 12–string version to any guitar model.
The GP–10 also includes polyphonic effects, such as the Crystal metallic sound, a Slow Pad for string-synth–like effects, and Polyphonic Distortion. This last one produces ‘singing’ distortion that you can use to play complex intervals on the guitar without generating the audio hash that typically occurs when you play chords and intervals through a traditional distortion. Fans of Roland’s GR–300 ‘80s guitar synth should be pleased to find a complete emulation of that unit. Finally, the GP–10 throws in the proverbial kitchen sink — a dual–oscillator polyphonic synth that generates fat leads or retro–cool pads, reminiscent of synths of the ‘70s and ‘80s."
I've had a GR-09 for over 25 years and also owned a VG-8 for a few years. I just refurb'ed my Heritage guitar that has a GK -2 pickup and I might easily go for something more modern sooner or later, but the heart of my system is actually an ancient EMU rack sampler and an old Rocktron MIDI switcher, both of which still work great. The GR-09 needs a new backup battery, which was a whopping $1.50 at Mouser. I'm very used to the tracking and can make it work plenty well enough to stay entertained for an hour or three occasionally, FWIW.
What model EMU are you using?
ESI-4000. My nephew gave me a few CDs of awesome industrial noises and high end synth samples and I installed a Zip drive in place of the original floppy disc reader. My old gigging setup included a reworked Laney tube amp and one or two 12s as the center channel, and then a solid state biamped stereo rig that worked for bass too. I doubled a lot back then, sometimes switching back and forth during a given song, even.
The EMU sampler is at the bottom of the lowest rack case. Heavily processed vocals were a big part of my schtick too.
