Cathode and fixed bias in the same amp???
wintercept
I know, I know. This is my second tube amp post on a pedal forum. This is a new low for me guys, I’m desperate. I posted a bit about this on Ampgarage and was blessed by a response from R.G. Keen, but the thread has lost traction.
I’m working on a VHT Pitbull Hundred/CL (yes the same one from March or whatever) and have working great, but I am struggling to bias it with the so called “Dual Class” mode. As I shared on the other forum:
In "Class AB" mode, all four output tubes are run in fixed bias, easy peasy. But in "Dual Class" mode one tube in each pair is switched entirely to cathode bias, with no negative voltage on the grid, while the other tube in the same pair is run entirely with fixed bias and the cathode grounded. The cathode biased tubes share a single resistor/bypass cap arrangement between them. The cathode biased tubes were red-plating in Dual Class mode while the fixed tubes were not. So, I increase the cathode resistors from 150R to 280R and brought the bias from ~120% to ~90% dissipation.
The issue I have now is if I set the fixed bias to say ~15 watts per tube in Class AB mode, switching the amp to Dual Class mode increases the voltage drop between B+ and the plates, from which I calculate that the fixed bias tubes are running at ~20 watts. If I set the bias colder to say ~17 watts per tube in Dual Class mode, they go down to around 8 watts in Class AB. So, I must be missing something here. Anyone here know how to bias this thing? What sort of idle dissipation should I look for in Dual Class?
For all the weird and novel tube ideas out there, I can't find a single reference or schematic for this kind of arrangement. This is not like Mesa's Simul-class, nor is it the hybrid bias like some late 60's Fenders where all output tubes have cathode resistors and negative voltage applied to the grid. It's literally one cathode biased tube next to one fixed bias tube on each end of the push-pull arrangement.
I do not have any answers or deeper knowledge, but I’d like to participate.
What is the endgame and purpose with dual class scheme? What tubes and how many? What is B+ VDC and cathode bypass cap value? How you planned partial cathode bias plan? Does B+ rise when you reduce bias tap load? Do you have a schematic? Have you how your build and voltage measurements fit into tube datasheet typical operation point references and max limits?
Thanks! Sorry I didn’t make it clear, it ain’t my amp.
It’s how the’s bad boys come. Here’s the owners manual: https://www.fryette.com/content/G100CL_SFD.pdf
Fryette doesn’t share schematics and nothing has been published for this amp except a partial preamp sketch of unknown origin.
After tinkering some more I think that biasing it in fixed/AB mode around 50% or so, what I normally do for an amp like this will work just fine. In dual class mode the cathode bias looks pretty perfect. I’m just scratching at how the fixed bias works in dual class mode because the B+ to plate voltage drop, thus the plate current, goes up.
Nothing wrong being set at 50% of max idle dissipation as tubes vary so much and 70% rule is max instead being ”sweet spot to aim”. I set my 4xEL34 UL amp at ~47%, sounds good and runs cool without worrying red plating.
Searching your dual bias thingie lead me to reading about enchanced bias circuit. I need to read more about it for sure!
Does dual mode bring anything uselful soundwise or is it a gimmick? Btw is there separate caps and bias leads for tube pairs, every tube or just one pot to adjust?
Yep I got it sounding really good around 55%. I’ve enjoyed the results as low as 40% for some high gain 6L6 amps.
The dual mode sounds different for sure, brings in more low mids but it’s subtle. The owner ran it in the “Class AB” (standard fixed bias) forever and only switches to dual class recently to try it, hence bringing it to me with the issues I fixed.
It has one bias adjustment trimmer for the negative bias like you’d normally find, then one cathode resistor and bypass cap for the pair that gets switched over in Dual Class mode.
Let me know what you find!
consider subbing the 47K resistor (RS6) in series with the bias pot for a 33K ... which I like less than just biasing a little cooler. my assumption is that fryette planned the cooler bias route with their design choices and lack of documentation
I saw that post pretty early on when I was hunting for info about the amp. I’m not sold on the assesment of the situation there…
I found the bias adjustment range on this amp to be quite large, from very cold to easily too hot. If I had trouble finding a suitable range with more than one set of tubes I’d suspect an issue in the bias circuit rather than the design itself, such as the caps or rectifier diodes for the bias supply.
The blog shares no measurements of the plate or bias voltages, nor the how the bias changes between AB and Dual Class modes or the cathode bias circuit. These amps also have a half power mode that shuts off two tubes so the bias should also be checked there. Since the plate voltage increases a bit with less tubes loading the B+, the two remaining tubes run slightly hotter.
All is well now and i know the amp is not gonna roast more output tubes.
