Bajaman DR103 Hiwatt Amp Emulation
ac30irons
Hey all,
Curious to know if anyone has knocked one of these up. I know there was a brother some time back having difficulty’s. This seems to have been resolved by highering the value of the resistor between Pin 6 and 7 on IC1. I would likely put a 20k trim here.
2SK117s are like rocking horse shit in the uk, would likely sub them out with 2SK209s.
Going to knock up a schematic on Eagle when I am back from my trip.
Any considerations would be appreciated.
There's some bajaman emus that I think only bajaman only ever had working builds of.
Probably a good idea to find some verifications before embarking on any of them.
So from what I can see the vero is verified, once the feedback resistor was de-bugged.
I’m thinking for the sake of a few £££ I can knock up a pcb and see how it is !
I have the AC 30 normal and top boost, SVT, 57, 5150 and the Reactor. All do work. The Reactor needed a nice layout and the 57 sounds strange when used with a humbucker but all work in general. His love for the 2SK117 is a problem nowadays but I switched to J201 or the SMT counterpart.
Did you build them or buy them built ? I know another place does some layouts for some - I haven’t seen any for the Vox stuff though !
2SK117 - pain ! You can get the SMD counterpart from Mouser which I will likely do, can’t be doing with the faf swapping resistors in and out if I change to another JFet.
Build them myself on PCBs from JLCPCB except for the 57 on vero.
I‘m this guy https://www.freestompboxes.org/viewtopic.php?p=300017#p300017 the files are one posts below.
Edit: thanks for the mouser hint. Will check them out when I order again.
And there are layouts for almost all of Bajamans schematics http://effectslayouts.blogspot.com/2018/10/bajaman-ac30-normal-channel.html?m=1
Thanks man, I’m going to do a layout on Eagle for the Hiwatt and maybe the Soldano. JLCpcb rocks. I can’t quite fathom how they do what they do for so little money. I was pondering on doing yeh Ac30 Normal channel also but I love the ROG Britannia.
2sk117 are used as buffers, so absolutely nothing special about them :) I tossed in j201 in my Baja builds back then because that's all I had. Use any small signal jfet, or even replace them with opamp buffers, it won't make a difference at all sound-wise.
Thanks man, saves me the headache of a Mouser order !
