Bipolar LED on DMI Dual Octave Pedal
VanWhy
Just ordered a Dual Octave PCB from Dirt Monger Instruments. It uses an DPDT to toggle 1 or 2 octaves with an individual LED for those 2 settings. (I plan on using 3PDT).
Can I just use a bicolor LED? Would that be common anode or common ground? Would it be as easy as wiring the ground of the bicolor LED to the cathode pads on the PCD and the LED anodes to the anode pads on the PCB?
Decide whether you want the switches to be on the + side or the - side of the LED. That determines whether you use common anode or cathode
Sometimes you need to take the PCB and move things around until you get the functionality you want.
The pedal looks like it's set up with 3 LEDs - one to indicate bypass, one for 1 octave up and another for 2 octaves up. The one oct up is always on. It's weird to me they did it like that but you can clearly see +9v to ground with no interruptions. And the switch is a 3pdt footswitch as indicated by the gut shot, not an on/off/on. Idk bro
If it were me I would have a bypass LED that's white or something and then a red/blue 1 or 2 octave up LED. You can accomplish this by populating a shunt in place of the D4 LED and then place D4 in series between the footswitch lug and ground. That's for three separate LED's.
To use a bicolor I would use a common anode LED and populate the positive side in D4, and then run each cathode to either side of the footswitch, with its middle lug going to ground. If you want to get the brightness to balance (ie blue is too bright) then add another resistor between the LED's cathode and the footswitch lugs. Lately I've been using trim pots, which is great for adjusting later on
Good call. This sounds spot on to me. Thanks for the response. I will post back when I get it built.
